  1. I am trying to back-up a DVD that does not have any "_" as spaces in between the words, so should I copy it exactly as it appears on my desktop, or should I insert the "_" where the spaces are right now.
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    It should be fine if you keep it titled just like it is now.
  3. Thanks. I will just leave the title as it appears on my desktop, and burn it as is.
  4. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    in all reality I dont think it matters really.......... but for simpliticy sake mine and other tutorials says ALL CAPS and _ for spaces to eliminate the possibility that a dvd player may not play them.
    these days most dvd players could care less............ so to ensure there are little to no problems its a good idea to put them in.
    yet if you know your player has no problems, there is no concern with leaving the _ out and using lowercase letters for the title name
