ok so i'm trying to make a kvcd out of a PAL XviD. problem is that whenever i try to convert the XviD into MPG using TMPGEnc, the video is jerky and kinda looks like it's going slightly in slow motion. at first i thought it was my XviD codec but i have no clue which one of the 50 million of them to download and install.
i've read the posts here looking for a solution and it seems others have had the same problem with XviD files but never with DivX and i've noticed the same. some posts have recommended that you convert the XviD to DivX and then go on to make the vcd/kvcd.
is that a good idea? i thought you lost quality everytime you convert a file from one format to another. but i can't seem to get these damn XviD files to play properly so i'm getting desperate.
and if it is a good idea...what's the best way to do it? i've read that virtualdub will do it but i'm not exactly sure what the steps are.
source: 25fps PAL 576x240
i'm trying to make a 528x480 kvcd
Yes, you lose every time you convert. Instead of re-compressing with Vdub you can frameserve it directly to TMPGEnc. No intermediate file required and no loss involved. Here's a guide.Originally Posted by appetizer"Art is making something out of nothing and selling it." - Frank Zappa
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 02:01 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25 -
Xvid to KVCD
By mjaeson in forum Video ConversionReplies: 8Last Post: 25th May 2007, 21:05
