Hi,
How do i convert from SVCD to miniDVD?? How big of a hard drive do i need for that?? I have a 40 gig. I know going from DVD to miniDVD using DVD2AVI and TMPGEnc Plus a 40 gig is not enough because i tried it. Can someone start throwing beginner guides out this way?? So i can learn how to do this. Even if u guys want to u can even give me guides on Divx to miniDVD?? Please reply back. Thanx guys.
40gb is enough for all conversions.. read the beginner guides
diff between svcd and minidvd
svcd 480x576
minidvd 720x576
cvd 352x576 (probably a better idea)
10gb is needed for conversion.Corned beef is now made to a higher standard than at any time in history.
Ok but what i was asking. Can u or someone give me beginner guides on how to convert from SVCD to miniDVD and from Divx to miniDVD?? I understand there different but i want to convert from those 2 formats to miniDVD. Please reply back. Thanx.
Converting SVCD to miniDVD is possible. First problem is an SVCD is 800MB's,but miniDVD is limited to 700MB's because it must be burned in mode 1. You would need to re-encode down to 680MB's. Once you have it to 680MB's demux it into m2v and mp2 streams. Re-name the mp2 to mpa.
Use IFOEDIT's DVD author mode. It makes no DVD compliance checks so it will convert the 480x480 to 720x480 in the ifo file and it will author the mpa stream even tho it's sampled at 44100. Test in your DVD player to be sure it can handle the 44100 audio. If it can't handle the 44100 you need to re-sample it to 48000 before authoring in IFOEDIT.
You would need to re-encode a DIVX to mpg2 then the same procedure.
TMPEG for encodeing,demuxing,and audio conversion.
Nero 6 has a miniDVD template to simplify burning.
An alternate method would be to demux and author the 800MB SVCD and then compress it to 700MB's with DVD Shrink.
Creating MiniDVD
By MI6 in forum Authoring (DVD)Replies: 7Last Post: 21st Nov 2008, 00:05 -
Can you capture from a MiniDVD camcorder?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 4th Sep 2008, 22:52 -
Finalize Sony MiniDVD on PC
By schematic2 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2007, 22:55 -
stripping and editing canon minidvd??
By aussiemac in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 12th Nov 2007, 14:37 -
Using files from a MiniDVD Camcorder
By djc38510 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2007, 10:57
