I have libmatroska, and libembl installed. I just cant get MKVtoolnix to compile and install. Does anyone have a compiled binary of it?
Q
"Good Luck 007"
In Memory of Desmond Llewelyn -
All I know is that it is a pain in the butt to compile and I would love the same thing
first i says that "cant find iconv library"
so i get the libiconv. i try and compile that, and it says its missing pieces. AHHHHHHHHHHHHHH.
its being a bitch.
Q"Good Luck 007"
anyone?
with suggestions?
or the binary itself?
Q"Good Luck 007"
Ok....so far this is what ive done, and this is what matroska.org said to do....
downloaded, compiled, and installed libmatroska and libembl without problems............
then downloaded mkvtoolnix, did the ./configure, and after about 50 lines of info, it says "cant find iconv library, please install"
so i get libiconv, ./configure it, then when i make it, it cant find one of is components.
so i search around in the file, and i find whats missing, so I correct it( instead of Iconv.lo it was Iconv.loT) then I try making it again..........AND ITS MISSING ANOTHER THING!
if someone has done this before PLEASE HELP MEEEE, or if you have OGM tools compiled or something.
Q"Good Luck 007"
mkvtoolnix and ogmtools can be found on darwinports:
http://darwinports.opendarwin.org/ports/?by=cat&substr=multimedia.
port will take care of the dependencies of mkvtoolnix, except expat, so you would want to install that first.
ogmtools are also available via fink, in the unstable branch. -
ive tried, it says the exact same errors.
im going to reinstall dev tools.
Q"Good Luck 007"
ProjectX compiled EXE version
By mr.duck in forum DVB / IPTVReplies: 21Last Post: 7th Aug 2013, 12:40 -
Need an OS X binary of mp4creator, anyone ?
By pawzlion in forum MacReplies: 4Last Post: 9th Dec 2012, 08:41 -
mpeg2enc binary not working
By yabastamedia in forum ffmpegX general discussionReplies: 1Last Post: 19th Jan 2011, 12:02 -
Slightly OT but...Where do Compiled programs go before installing?
By GMaq in forum LinuxReplies: 3Last Post: 17th May 2008, 13:12 -
Problem with mpeg2enc binary
By lkearl in forum ffmpegX general discussionReplies: 1Last Post: 11th Aug 2007, 03:47
