Hallo,
I recently begun to make dvds, and still havent found the final sw.
I installed dvdit, and i like the versatility and wide range of posibilities, but i couln't capture via Firewire tha images (i had them in mini dv), so it took me longer to prepare the mpge-2 file.
Is it that i didn't know how to do it, or it just can't be done???
hi, i didnt realise you could capture with dvdit?
what i tend to do is import video from camcorder into
adobe premiere uncompressed then edit the avi and
export to adobe mpeg encoder.then the finished file
i load into dvdit for menus,chapters etc..
hope this helps -
Hallo nada, that's what i had to do, but i know some software for dvd authoring that you don't need to capture to premier (or the sw you use), and wanted to know if i can do it with dvdit. I found lately that dvdit reads qt ref clips, wich helps a lot (in time)
Try that
subtitles with DVDit 6 PRO
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2010, 14:51 -
Replacement for DVDit Pro HD 6.3 Final
By GrampaD in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2009, 12:04 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 23:40 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 02:08 -
DVDit Pro HD and Sript error in activation
By arturjose in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 01:51
