I know this topic has several times be here, but i can't get satisfied answers. So what can i doo if i have several VOB files and want to make a DVD with menu or edit an existing menu. It should be done without recodeing the VOB files, so just a menu and a chapter system. Damn that can't be so difficult. Hope some one can help here. I tried TMPEGEnc DVD Author for using MPG and VOB files, and it's not a bad proggy, but the Menu Creation part is totaly shit. So i thought i make my DVD with TMPGEnc author with a shitty menu and the i edit the menu with another proggy, but which should i use
N8mare
Yep, thx man that's the solution i was looking 4. The proggy does exactliy what i want.
N8mare
Need recommended software to edit videos and create a DVD
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 14th Feb 2011, 12:09 -
How do I create a DVD Menu
By RKM1552 in forum Authoring (DVD)Replies: 6Last Post: 23rd Feb 2010, 13:19 -
How do I create a DVD menu?
By RKM1552 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Feb 2010, 07:42 -
What program do you use to create a menu for DVD
By Cazz in forum Authoring (DVD)Replies: 6Last Post: 24th May 2009, 13:31 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
