Hi !
I have problems converting an svcd file to divx. I follow the tutorial but i can't apply the resize filter when i use fast recompress. I've searched the net for an answer and found this :
VirtualDub runs in RGB when you use Normal Recompress or Full Processing Mode (in the Video dropdown menu). All of VirtualDub's internal functions and filters run in RGB colorspace only. However, Fast Recompress doesn't decode the video to RGB, and instead just shunts whatever your source is into the compressor you've selected - thus if your source is YUV it shunts the video data as YUV into the video compressor
Is there a way to do what i want or not. Is the tutorial wrong ? Am i a dick ?![]()
Results 1 to 9 of 9
I've never tried a svcd to divx conversion using "fast recompress" or "normal recompress". I always use "full processing mode" and the resize filter works just fine.
That's what I figured. What are "normal" and "fast" recompress used for then?
check here for a good explanation of the video processing modes in Virtualdub and why to use one over the other. https://www.videohelp.com/forum/userguides/145121.php
hope this helps as much as it has me. -
Thanks for the link, as this will be good to know in the future. However I can't think of too many situations I'll have the chance to use fast recompress because I use filters for damned near enverything.
To work in the same colorspace (YUY2) using fast recompress in Virtual Dub, use avisynth to create an avs file to load into VirtualDub. In that AVS file you can resize the file in a breeze and you will be able to encode with less quality los and at a faster rate than normal/full recompress.
Oh, and avisynth has a lot of other filters you can use in place of virtualdub filters... though the options of previewing virtualdub filters makes it quite nice.
DVD (MPEG2) or DivX
By MI6 in forum Video ConversionReplies: 1Last Post: 20th Sep 2010, 14:51 -
vob/mpeg2 to Divx close to Dr Divx?
By Tiribulus in forum Video ConversionReplies: 8Last Post: 5th Dec 2009, 12:52 -
divx to mpeg2 with winff = error
By tors10 in forum Video ConversionReplies: 2Last Post: 12th Dec 2008, 15:58 -
DivX and MPEG2 capture devices
By Arcturus in forum Capturing and VCRReplies: 18Last Post: 25th Aug 2007, 00:49 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 30th Jul 2007, 00:57
