does any know why i can't open this file
Results 1 to 10 of 10
TMPGEnc does not support WMV files. You need to convert it to another format or try to get a hold of virtualdub 1.3c. This was the last version of virtualdub that supported asf and wmv files.
If in doubt, Google it. -
I open WMV files with TMPGEnc quite often to convert to VCD and SVCD. No issues, just install the Windows Media 9 Codecs. It will allow WMV files to be opened in TMPGEnc.
Fixed it for me and several others.
http://www.microsoft.com/windows/windowsmedia/format/codecdownload.aspx -
do you know how to change the file extensions to .asf i tried renaming and adding .asf to the filename but that just makes it filename.asf.wmv
Originally Posted by movie freak
Ripbot 1.13 won't open
By wulf109 in forum Blu-ray RippingReplies: 2Last Post: 9th Feb 2009, 10:45 -
DivFix++ v0.30 won't open
By Bix in forum Newbie / General discussionsReplies: 3Last Post: 26th Jun 2008, 23:40 -
Large DVDs won't open
By newtie in forum Authoring (DVD)Replies: 2Last Post: 27th Sep 2007, 19:53 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 09:16 -
OGMDemuxer won't stay open...
By deepdiev in forum Video ConversionReplies: 3Last Post: 13th Jul 2007, 02:07
