Hi everybody,
Just bought a pioneer a06 burner, and it works fine, but on a number of disks, 3 out of ten etc, it makes a jitter error or so, or theres a little part of it that wont be played??
I'm using dvdshrink to convert and imgtool to burn.
I was wondering if it could be my 256 mb RAM?? Is that enough? I've normally close all other programs icq, messenger etc.?
Or should my drive be master or slave, I have a combi drive to!
Hope somebody can help-`?
Thx-
Kongz
It would help if you mentioned your OS and cpu speed as well. 256 meg ram should suffice if there are no other aps running, but more ram is always better.
I have the Pioneer A06 and run WinXP, a P4 1.6 GHz, and 384 meg ram. I still only have Nero 6 running when burning a DVD, altho I do still have firewall, and virus program running at the time.
Also, make sure that your burner is on a different IDE channel than your hard drive. This is probably the most important.TANSTAAFL -
I'm using a p4 2.4 ghz dell machine With 256 mb ram. How do I check the harddisk is not using the same ide channel``??
could it be because I'm burning in imgtool, should i rather use Nero?? even if they use the same aspi??
Thx
FAT32 file size and Pioneer player dilemma
By umniy2000 in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2011, 19:17 -
Pioneer 533 DVD-R Burning Problem/Question
By tcfrerich in forum DVD & Blu-ray RecordersReplies: 27Last Post: 23rd Oct 2009, 12:03 -
RAM problem?
By seven1970 in forum ComputerReplies: 4Last Post: 13th Mar 2009, 07:05 -
Question about burning file size
By magikero01 in forum Newbie / General discussionsReplies: 7Last Post: 3rd Jan 2008, 07:34 -
Burning to DVD RAM DISK and then play on your TV
By pmorris1 in forum Newbie / General discussionsReplies: 5Last Post: 25th Dec 2007, 18:15
