I am trying to burn a movie(predator_dvdrip_xvid.avi) using nero 6.Each time i try it keeps telling me its a unknown or not a valid file format.What do i need to do to be able to burn this movie?
Convert it from XVID to MPEG2 and author it.
Probably best (and quicker) to use your original disc and just rip that...
Youre not able to burn divx/xvid directly into DVD format by simply burning onto a DVD.. As a previous poster has stated, you must first convert to mpeg/.vobs in order for it to be compatible to play in a standalone DVD player.
I'm trying to burn it as a dvd.If i need to convert it to a compatible dvd format which program should i use to change its format?
Look to the left under convert. There you will find guides to convert your avi to mpeg dvd.
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
Can't shrink "Predator 2". Any ideas?
By burgurne in forum Blu-ray RippingReplies: 6Last Post: 18th Dec 2010, 16:53 -
U.S. Predator drones hacked with $26 software
By deadrats in forum ComputerReplies: 21Last Post: 20th Dec 2009, 10:48 -
Aliens Vs Predator 3 FPS PC Game?
By retroborg in forum Off topicReplies: 0Last Post: 28th Jan 2008, 08:34 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28
