I want to combine 2 DVD's of 30 minutes to 1 DVD of 60 minutes. DVD Shrink should do the job. I tried it (in the Re-author-mode), but it doesn't work. It's not possible to select 2 different DVD's (only 1). Any advise?
This is probably very unorthodox, but here's how I do it ...
* Extract the VOB's to different directories using the DVD Shrink.
* Use VOB Merge to merge the 2 files (save un another directory and name the resulting merged file VTS_01_001.VOB
VOBMerge -- http://www.digital-digest.com/dvd/downloads/vobmerge.html
* Use IFOEDit to create a new IFO for the merged VOB file (Open IFOEdit and click on CREATE IFO button)
Not the only way, I'm sure, but works for me. -
You can do this with the Re-author fuction, but you have to rip both DVDs to the HD BEFORE running DVD shrink. Here's what you do:
1) Rip DVD A to HD in it's own dir (eg. A/VIDEO_TS)
2) Rip DVD B to HD in a seperate dir (eg. B/VIDEO_TS)
3) Run DVD Shrink
4) Open the folder with the ripped DVD A, choose re-author, drag and drop
5) Open the folder with the ripped DVD B files, the re-author window stays open while you do this, then drag and drop again.
This will create a new DVD to compile. You will lose the menu(s) but keep the chapter points. -
Originally Posted by Vejita-samaIt appears that the CPU was operating so fast that it began to execute instructions before they arrived. This execution of future instructions created a small tear in space-time itself through which part of the cpu passed into a parallel universe
I'm just curious as to why you'd want to put 6 hours of SVCD quality on a DVD. The only two reasons I can think of is that you'd be too lazy to walk over and change DVDs once every 2 hours or you're too cheap to spend another $1.50 on 2 more blank DVDs. Is there a 3rd?
Originally Posted by BobK
,but being new to DVD burning i wanted a project to see what i could do with my AO6 and a few films and have acceptable sound and audio quality, and help me learn the limitations and "quirks" of the diffrent software i use.
Combining DVD's
By grandsire02 in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2012, 07:06 -
Combining 2 DVD's help
By rede96 in forum Newbie / General discussionsReplies: 2Last Post: 30th Nov 2009, 14:35 -
Combining Three Mini DVD-RWs Into One DVD
By canon10d in forum EditingReplies: 2Last Post: 10th Aug 2008, 18:42 -
Combining 2-30 min handycam-dvd-r's onto one DVD-r
By mainiac1 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jul 2008, 22:37 -
How to make a new combo DVD Menu for combining existing DVD's
By Scav2003 in forum MacReplies: 3Last Post: 16th Oct 2007, 06:21
