Hi guys,
I've just got my Philips DVDr70 through and have noticed that the pixelisation is fairly obvious in all recording modes other than M1. Is this normal?
My TV reception isn't perfect, it is a little grainey, would this affect the pixels?
Many thanks in advance for any help!
Yes, this is one of the flaws of digital video. If there is some noise in the picture, the recorder will often interpret the noise as details in the picture, thus wasting valuable bits for nothing.
The only suggestion I can offer is to try replacing the incoming cable (if possible) with a higher quality one, which can often lessen the noise. -
hi,
i have had this recorder for about 5 months, i only ever notice pixilization when i record in 6 hour mode, but even then that is barely noticeable.
DVDlab Pro: Text set as visible isnīt visible in the result
By Alex89 in forum Authoring (DVD)Replies: 14Last Post: 12th Aug 2010, 08:09 -
how do I convert a video that shows square pixels to no pixels?
By sxpredman in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 03:56 -
Another question: Converting square pixels into round pixels.
By Earthling2000 in forum Newbie / General discussionsReplies: 13Last Post: 23rd Nov 2009, 11:20 -
Firmware problems DVDR70/021
By Xavier in forum DVD & Blu-ray RecordersReplies: 6Last Post: 17th Oct 2007, 23:46 -
Video not visible in editing software/visible in Media Player
By kb1985 in forum Newbie / General discussionsReplies: 1Last Post: 1st Aug 2007, 19:21
