Just got this burner in today and use very cheep media to see if the burner would crash. I use KHypermedia it burned with no problem's. The ripping speed is about 3.6. I'll give more info on it when I can test more on this DVD burner.
Also want to point out it great for download file's right on the DVD-RAM no more download to the hard drive then backing up on CDR's or DVD-R. This is what really show's off DVD-RAM.
Just want to make a update. I ripped duel layer DVD took 14:43 minute's for a 6.72gig dvd. Ripping speed change's as it ripp's about 7.7 or is the average speed start of slow then speed's up then slow down at 5.4. So it start out at about 3.6 then goes half way hit's 7.7 then the end of the DVD hit's 5.4. i used Smartripper
This looks like a fantastic DVD burner from the specs I've seen, just wondering if you've used it under windoze at all and if so what software you used to burn discs with. The drive doesn't appear in the easy cd or nero supported drives list yet...
Thanks for the info you've already given, it's nice to be able to think about purchasing based on reviews rather than manufacturer hype.
Steve -
Even if Nero doesn't work, at least the software that came bundled with the drive should work, I would think.Originally Posted by elstcb2
Roger that.... it's nice to be able to think about purchasing based on reviews rather than manufacturer hype.
I'm looking at getting an OEM drive and am looking to cover my back in case there's no software at all with it.Even if Nero doesn't work, at least the software that came bundled with the drive should
spiderman2k1: thanks for the feedback, again nice to know what software to purchase if the drive doesn't work with what I've already got
Wi-Fi foe sues neighbor for using electronics
By deadrats in forum Off topicReplies: 1Last Post: 11th Jan 2010, 21:58 -
Are you using wireless headphones with your electronics?
By yoda313 in forum PollsReplies: 13Last Post: 11th Dec 2008, 16:10 -
Are electronics shows important to you?
By yoda313 in forum PollsReplies: 9Last Post: 12th Jan 2008, 19:14 -
Does product design for electronics influence your purchase at all?
By yoda313 in forum PollsReplies: 10Last Post: 24th Aug 2007, 07:52 -
Are electronics more durable than they were 10 years ago?
By yoda313 in forum PollsReplies: 29Last Post: 25th Jun 2007, 21:19
