I jus got a Dazzle DVCII and I want to record an avi from my pc to a VHS tape with my DVC2, what i have to encode it as, I have TMPGenc. What settings do i use, i've tried everything and MovieStar couldn't import the movie. Ive tried SVCD,VCD, and DVD Templates, and moviestar still can't import them, whats wrong with this?
Personally, after I encode with TMPG I burn it to cd and then record to tape from my DVD player. This way you can use whatever encoding you like that is compatible with your dvd player without fighting with Dazzle or Movie Star.
I have no problem in importing MPEG1 and 2 files even some non-standard bitrate file to MovieStar. Check your TMPGEnc settings in encoding the avi file.
yeah, i created a vcd with nero and it accepts the dat file, is it possible to make a virtual video cd, thats on my hard drive?
what settings do you use for TMPGenc? i used the vcd, svcd, and dvd templates and none worked.
Dazzle Video Creator Plus Help Please!
By FragpooL in forum CapturingReplies: 1Last Post: 23rd Jun 2011, 23:51 -
Video to Dazzle and Tv
By fellixombc in forum CapturingReplies: 1Last Post: 6th Jul 2010, 15:52 -
What digital video format compares to Digital 8?
By jungleexplorer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Dec 2009, 15:00 -
Dazzle Vid Creator Plus, or TV tuner card?
By cwb in forum CapturingReplies: 3Last Post: 21st Jul 2009, 08:38 -
Dazzle Digital Video Creator 100 (DVC 100)
By Rockin Rayzor in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 16:08
