i want to join two 1 hour programmes into one large file so that i can encode them using tmpgenc overnight but i cant seem to get my captured files to open in any editing tool ive tried so far, what format does my canopusADVC capture in using WINDV i thought it was avi but ive tried to open these in a few programs and they dont recognise it!!! any suggestions of programs that do this!![]()
I have the same problem. I can't get anything to open up what I captured. I want to burn to dvd, but I cannot open the mpg in anything.
windv, like several other capture apps. gives you the choice to cap to type 1 or type 2 dv. Type 2 seems to be preferred/required by a good number of editing/authoring apps. See Glossary for more info on AVI and DV.
efiste2 - one thing you might do with your two exisitng files:
If TMPGenc accepts them as is, go ahead with your editing/ encoding using batch encoding and then using TMPGenc's MPEG Tools menu, simply merge the two mpeg files into one, if that's what you want.
If needed, Canopus support should have a free convertor utility for download.
Canopus ADVC 300 DVD Capture Now?
By Detta in forum Capturing and VCRReplies: 7Last Post: 20th Sep 2011, 14:02 -
Which Canopus DV capture box is best?
By Knightmessenger in forum Capturing and VCRReplies: 6Last Post: 26th Dec 2010, 18:59 -
Anybody Need a Canopus ADVC110 to Capture With?
By Endzone in forum Capturing and VCRReplies: 2Last Post: 8th Jan 2009, 17:09 -
Capture problem with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 26th Dec 2007, 21:20 -
DV Canopus Capture to XviD with MeGUI?
By Robert Simandl in forum Video ConversionReplies: 0Last Post: 21st May 2007, 17:43
