i'm converting XviD to standard VCD using TMPGEnc. used the bitrate calculator to figure out how to get a 100 minute movie into one 80 min CD-R. told me to do it at 950k for video and 128k for audio....lo and behold the file size comes out to a little over a gig.
what gives? i tried using the TMPGEnc wizard, but it comes out with the same result, a 1 gig file. could it be because the movie has a lot of action/movement?
much appreciated.
VCD is 800 MB per 80 minutes fixed, carved in stone, won't ever change.
Don't try and change the bitrate, TMPGEnc won't let you since you are using the VCD template.
Now if you load the UNLOCK.MCF file, you can create an MPEG system stream and set your bitrates. Don't expect it to look any good, it's simple too low a bitrate for MPEG1.
Search KVCD and xVCD for tips on 1 CDR movies. They use non-standard GOP's to get better results (but some players get confused).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Decompress your audio, then try it using the standard VCD template
Just shut up and listen dumbass
Output Size of PAL VCD Rendered In Sony Vegas Pro 10 Is Too Huge
By LeHuoXuan in forum Authoring (VCD/SVCD)Replies: 8Last Post: 28th Feb 2011, 21:40 -
quicktime pro will exporting to h.264 solve this huge file size issue?
By cybershot in forum Newbie / General discussionsReplies: 7Last Post: 10th Oct 2010, 21:43 -
WMV to Avi(xvid,mp3) using VirtualDub - huge destination file
By chm in forum Newbie / General discussionsReplies: 9Last Post: 20th May 2010, 17:29 -
Making XVID videos with VirtualDub: output files w/huge file sizes (~1GB+)
By maskingtape in forum Newbie / General discussionsReplies: 11Last Post: 4th Mar 2010, 23:50 -
Help dubbing avi without make file size huge
By method in forum Newbie / General discussionsReplies: 4Last Post: 10th Aug 2007, 03:51
