Hi!
I am trying to fix an Xvid-file, I use VirtualDubMod and scan the file for bad frames, that works.
But if I try to delete hte frames I`ll get this error report: "An out-of-bounds memory access (access violation) occurred in module 'xvid'...
...while decompressing video frame 5886 with "XviD MPEG-4 Codec" [biCompression=44495658] (VideoSource.cpp:1823)."
How can I delete the bad frames when this program is unable to do it?
Thankz for any help!
Results 1 to 9 of 9
We came, we saw, we kicked his ass!
If the program crashes then make note of the exact frame number as reported by Vdub. Use "go to" under "Edit" to move the slider and mark and delete around the bad spot, you can then save a copy without that section be sure to select "direct stream copy" under audio and video. For instructions on marking and deleting with Vdud check the "Edit" section over there <-<-<-.
Hope that's clear enough, good luck."Art is making something out of nothing and selling it." - Frank Zappa -
Thanx!
I have a different problem now, it`s and Xvid file with a VBR audio part, I have saved the audio as wav and converted it into a mp2-file and used it to make a SVCD, but still the audio is out of sync, but now it comes to earli, any tips about this?
Newer had this problem before, it has always worked when I converted the audio!
Gracias...We came, we saw, we kicked his ass! -
If it's out by a fixed amount then I can tell you how to fix it using Vdub.
If it gets worse as the movie goes along then that's more difficult.
Let me know."Art is making something out of nothing and selling it." - Frank Zappa -
It's out by a fixed amount, and it seems to me that it dont change at all!
To fix audio sync problems with vitualdub that just needs delay adjustment goto audio/full processing and interleaving and skew correction and input the amount you need to delay or place it a bit further and save as with video selected as direct stream copy,you can see how much time you need by the voice to lips delay in the video near the end and roughly calculate.
That was my suggestion with a couple of additions....Originally Posted by johns0
You can check the delay adjustment by playing the file within VDub, use the buttons at the bottom of the main screen. Make your adjustments until it's perfect then you set your audio and video to "direct stream copy" and save avi. Instead of saving you can frameserve the video and audio directly to your encoder, there's a Vdub frameserve guide in the "Edit" section.
Good luck.
ZippyP,thanks for the further tips,didnt mean to take over your post but i got in a typing frenzy and sent my advice and noticed you said you would help on the matter.
Not a problem, you never know if someone's around to answer or not.
ColorTools 1.4 crashes Virtualdub
By LSchafroth in forum RestorationReplies: 10Last Post: 26th Apr 2013, 09:28 -
VirtualDub crashes when using MSU Subtitle Remover :(
By ralf07 in forum SubtitleReplies: 1Last Post: 17th Mar 2012, 03:16 -
Olympus camera memory card crashes virtualdub
By snafubaby in forum Newbie / General discussionsReplies: 4Last Post: 1st May 2011, 01:08 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
Virtualdub crashes
By Kevlin in forum EditingReplies: 2Last Post: 18th Jan 2008, 23:01
