Ok, slightly different question then the one nobody answered..
Anybody know if transferring DVCPRO to miniDV causes a significant loss in quality? It would make it easier for me to edit from miniDV with less quality loss than converting to DVD MPEG-2.
TIA
DVCPRO and DV is almost the same quality. I have not seen any device that will change the digital stream from DVCPRO to DV, so you will have to use the composite or S-Video to "record" the DVCPRO video to DV format. Some DV camcorders have analog input so you can convert to DV on the fly. You should see very little degregation going from DVCPRO to DV.
DVCPRO HD Quicktime File
By foochuck in forum Video ConversionReplies: 7Last Post: 27th May 2010, 05:33 -
stripes on playback of DVCPRO tapes
By myongsun in forum Capturing and VCRReplies: 1Last Post: 25th Apr 2010, 13:15 -
DVCam or DVCpro?!
By B-Twien Bytes in forum MediaReplies: 0Last Post: 18th Oct 2009, 08:32 -
DVCPro 25/50 importing to Premiere?
By LuckieGW in forum EditingReplies: 3Last Post: 1st Mar 2008, 20:59 -
how to play QT file( DV-DVCPRO 29.97 ) in FCP without PULLDOWN
By Radoje in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 6th Jan 2008, 21:50
