I am putting a series of 6 x 30min avi's onto DVD as VCD's.....in general that's going OK.
Episodes 1,2 & 6 are done.
3,4,5 are causing me a headache:
Episode 1: 448x352/25fps/48khz - split out the audio in Vdub, used TMPGEnc to produce the Mpeg - fine, no probs.
Episode 3: same details as above - TMPGEnc wants to make an Mpeg 122 minutes long, and 1.22gb !! (episodes 4 & 5 are similarly wierd)
And I have acanned for bad frames.
any ideas folks ?
Scrums,
https://www.videohelp.com/tmpgenc#problems
Fifth one down, is this your problem? Try doing what Baldrick says and post up again if it doesn't work for you.
CobraDMX -
Sorry, should have said: there IS a priority of 2 on that, AND the .wav was put in separately.
Think I've solved it.........converted and saved to .wav @ 44.1khz rather than 48khz, and the file sizes/times are realistic.
Haven't made Mpeg yet though !
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 15:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 16:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 18:56
