Hi all and thanks for previous advice.
I encode a divx avi file to a VCD without problem using tmpgenc plus. I split the sound and video first and check for errors with Virtual dub 1.5.10 before processing (no errors found). The process goes fine, but the vcd freezes in my sony 315 player about 18 minutes in. This process has worked before a number of times. The only thing that I can think is different is that g-spot tells me the avi file is MPEG-4 rather than MPEG-3 before running it through tmpgenc. I can watch the AVI file on my pc without any problems.
Any advise?
But can you watch the mpeg file on your pc without any problems?
"Art is making something out of nothing and selling it." - Frank Zappa -
my bad, it plays just fine in my CD-rom in my pc.
VCD-gear lists the bit rate as a straight 1150 as it should. divxrepair finds no errors in the avi and vcdgear finds none in the mpg. -
Try some different disks, maybe a CD-RW. Try burning at a low speed like 8X.
I've burnt on several phillips cd-rw at 10x and a tdk cd-r at 16x with no luck.
Windows media player freezes at each chapter
By stem300 in forum Software PlayingReplies: 2Last Post: 23rd Jan 2012, 22:37 -
DVD Shrink disc freezes in Win Movie Player
By visionman in forum Newbie / General discussionsReplies: 3Last Post: 5th Jul 2010, 08:12 -
MPG file from Sony P7 freezes in WMP and editing programs
By jlehrer in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2007, 09:34 -
Vcd freezes
By notebookguru in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Dec 2007, 15:00 -
computer freezes when encoding
By persiani in forum Authoring (DVD)Replies: 3Last Post: 17th Jun 2007, 18:23
