Hi,
I've captured a video with my tv card (it's in analog TV).
My video is captured in 352*288 (VCD PAL) and the broadcast quality was not very good.
I have used some filters in avisynth and they work grey to watch the video in normal size but when I play it full screen (I'm on 800*600), I can still view the defaults which were pratically invisible at normal size.
PS: The screenshots may take sometime to appear because the server is not very fast at certain time.
Here is a screen from the original source:
The same video encoded in mpeg (vcd) with the following script:
Code:avisource("d:\travail video\et alors.avi",false) letterbox(64,64,0,0) TemporalSoften(4,4,8)
and when I play it fullscreen:
The diagonal noise is still visible.
Here is my question:
Which filters can I use to improve the video quality. If it's possible.
Thanks a lot.
I think the quality is acceptable since your encoding in vcd quality. Why don't you try upping the bitrate or encoding to a different format?
I know, But i've captured this video a time ago and when I had win98SE I can't capture at 480*576 without dropping Frames.
Now under Windows 2000 I can capture a lot better but this music video is not broadcasted anymore on TV
How Can I Improve my video quality
By legend10 in forum Newbie / General discussionsReplies: 36Last Post: 23rd Feb 2012, 14:01 -
How would you improve the quality of this video?
By choobies in forum Newbie / General discussionsReplies: 0Last Post: 28th Nov 2011, 12:24 -
Improve video quality [HELP]
By v1rto in forum Newbie / General discussionsReplies: 8Last Post: 13th Jul 2011, 08:46 -
how to improve video quality?
By George2 in forum ProgrammingReplies: 1Last Post: 19th May 2009, 02:07 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38
