Hi all -- this is my first post here, so I'll make it quick (and I apologize if this has been covered -- I just can't find it anywhere).
Here's the deal : I'm using Apple's Compressor 1.1 application to prepare my MPEG2 files for DVD. Compressor gives me two files -- the video file and a "DVD PCM - aiff 48 Khz 16 bit stereo" audio file.
I'm trying to use Sizzle to author my DVD's -- and it accepts the video file just fine -- but it does NOT accept the audio file. Gives me a "could not open source - no audio tracks found" message. All right -- so what can I do? I've tried converting that file to other formats but nothing seems to work -- and according to the Sizzle "help" info -- the PCM file SHOULD work without having to tinker with it anyway.
What audio format will work best with Sizzle? And how do I convert the PCM files to the desired format? Is there something free I can use -- or can I do it in Cleaner, Quicktime Pro or some other app I already have?
I've read about A.Pack -- but I don't have that.
Any suggestions from Sizzle experts? Thanks in advance!
Results 1 to 1 of 1
What is the best compressor to use???
By BobAchgill in forum EditingReplies: 7Last Post: 13th Sep 2011, 06:55 -
MPEG2 Encode - Scene Change Detection (Apple Compressor vs Adobe vs other)
By rallymax in forum EditingReplies: 7Last Post: 21st Jan 2011, 19:44 -
Compressor gives me .h264, but....
By whoisquilty in forum MacReplies: 4Last Post: 10th Jan 2011, 11:38 -
HDV7 compressor is ..... ?
By ermetekos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 3rd Nov 2009, 14:00 -
HDV to Apple PNG or Apple Motion JPEG A
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 1st Dec 2008, 15:46
