hi i put the thin red line onto dvd ussing dvd shrink and nero plays on pc fine ut not standalone ????????
Results 1 to 12 of 12
Have you checked to see if your player supports the media you are using ?
yes checked here it is a pacific 750
i no copys work cause i have them from other sources. -
What do you mean other sources, if you are only using dvd shrink then there should be no problem. Have you tried using different media ?
there could be a media quality issue. if its cheap media it may have problems. also what settings are you using in Nero? If you aren't burning in the correct UDF setting then it usually results in DVDs that play fine in the PC but won't play in a standalone.
Have you tried it with different media or in a different player on the one that does not work ?
Could also be a PAL/NTSC issue. My Samsung standalone refuses to play PAL.
are you burning disc at once and finalizing the disc after burn in Nero? If not, that might also be your problem.
find out what version of Nero you are using. so long as is version 6 or up or some of the very latest V5, update if you don't have it, then you should use the DVD-Video template.
Sounds like media , I find that only certain media plays on standalone's . Cheap Disks cause serious problems in fact the cheapest disks won't even play on the Writer that I burn them on but they work in most DVD-ROM's
How to transcode HD .MKV file to watch on standalone 480p DVD Player?
By prankstare in forum EditingReplies: 4Last Post: 26th Mar 2012, 17:39 -
watch TV on my PC?
By wcwman18 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jul 2011, 03:35 -
How much tv do you watch a week?
By johns0 in forum PollsReplies: 36Last Post: 1st Feb 2011, 01:00 -
Watch 1080p
By anirban in forum Newbie / General discussionsReplies: 4Last Post: 7th Oct 2008, 11:17 -
Canīt watch videos
By General Mortars in forum Newbie / General discussionsReplies: 4Last Post: 27th Oct 2007, 09:48
