I've been encoding jpeg slideshows using the Microsoft MPEG4 V2 codec for a while now and naturally this is the codec that is used for playback as well. However before I re-formatted my HD several months ago I was able to use DIVX 5.05 as the playback codec. How can I set my DIVX codec to control these files again without uninstalling MPEG V2, and at the same time leave the door open should I need to change it back? Any suggestions would be appreciated.
Teegee420,
Not sure, but this might be what you're looking for. Certainly helped me when I needed to use DivX to play back XviD files.
https://www.videohelp.com/tools?tool=357#comments
Hope this helps,
CobraDMX -
Ahh well....
I don't suppose that if you went into ffdshow proprties and disabled the MJPEG codec it would fall back on DivX to play it back, and once you were done you could re-enable the codec?
I don't really know what I'm talking about here, but that seems logical if a little novel.
CobraDMX
Need help with codec for .flv playback
By 2ndHandGizmo in forum Software PlayingReplies: 2Last Post: 2nd Mar 2012, 11:53 -
Handbrake playback codec?
By jfharper in forum Video ConversionReplies: 2Last Post: 8th Nov 2011, 20:52 -
hard copy subs without changing codec fast
By Ceesar in forum SubtitleReplies: 15Last Post: 21st Oct 2010, 11:38 -
Snow codec playback
By leghorn in forum Software PlayingReplies: 2Last Post: 6th Jan 2009, 06:06 -
Super fast video playback - framerate changing, timeshifting
By KOJV in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2007, 00:20
