  1. I am having a problem where i ripped a movie off of a dvd-r but when i put it in primo dvd to burn it says something about errors and then when i try to put it thru dvd shrink it says somethnig about the ifo file ..... but all the other vob files play perfectly....... is their a software that repairs that main ifo file or is there another way for me to do this ???????
  2. Member waheed's Avatar
    Jul 2003
    Manchester, UK
  3. Originally Posted by mol3000
    I don't use Primo DVD but exactly, what files did you ripped and in what mode?
  4. first using smart ripper then using dvd decryptor i rip in all " FILE MODE " and ripp all files to a video ts folder like i usuallly do......
  5. dvd2one can generate a whole new set of files for ya.
  6. thanks handy thats one thing i wll try out but i also wanted to know how to fix it thru ifoedit.... i pull the file up in it but didnt know what to do.... i just resaved it thinking if it saw anything wrong it would fix it but it didnt
  7. ok.... dvd2one didnt work...... so how do i make this thing work using ifo edit ??????
  8. bump //// stlll need help on this one guys
