To explain the situation fully, my brother has an old tv which only accepts coax input. I have the rabbit ears hooked into the VCR and then the VCR into the TV via coax. I then have a dvd player hooked into the AV2 on the VCR.
I've told him a thousand times that he should stop being a tightass and buy a new tv but he won't listen. Anyway, his problem is that some commercial DVDs are shaky - as if the tracking is a bit dodgy. The same discs are fine on my DVD-TV combination and my PC.
I think it is because we are running it through the VCR. I do not wish to hear anyone who says "buy a new tv" because I know there's a 99.99% chance this will fix the problem. What I am after is confirmation that the VCR is the cause and if anyone has worked out a fix.
If in doubt, Google it.
Get a DVD modulator (they sell them everywhere) and don't run the DVD through the VCR. BestBuy and RadioShack has one for like $20 that automatically senses when the DVD is on and switches to that device.
You can buy a video stabilizer at your nearest electronic store to get rid of the macrovision thats kicking in when you run the signal thru the vcr to tv.
yeah macrovision seems to be the problem here, macrovision is a copy protection thing put on dvd's so when the disc has macrovision if you hook it up through a vcr the macrovision causes the picture to be distorted (to stop piracy). You could also try looking for a macrovision hack on the net that will disable it on the player.
I could dance with you till the cows came home..... on second thoughts i'd rather dance with the cows till you came home.
Rufus T. Firefly (Groucho Marx) -
Yep macrovision. If you cant find a hack for your dvd player, you could try backing up the dvd to a dvdrw or a dvdr if you are not bothered about using up the discs. This removes the macrovision protection then you should get a somewhat improved picture.
I have 2 dvd players one hooked up through the vcr so i can back up to tape if i want to and the other just straight to the tv which i use just for viewing.
If you dont have a dvd writer it will also work as an svcd or vcd if your dvd player supports these.
"Pull your tongue out of my ar$e hole Gary...dogs do that. Your not a dog are you Gary?"
"Err no...."
"But you do have all the characteristics of a dog Gary...all except loyalty."
Have a Magnasonic DVD816-4 Player - Bought DVDs "Probhited to play by CSS"
By Butterflyna in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2010, 22:46 -
What DivX standalone players play "BRRip.XviD" files?
By Stealth3si in forum DVD & Blu-ray PlayersReplies: 8Last Post: 10th May 2009, 21:14 -
Making videos "for sure" playable in standalone player
By Meagain in forum Video ConversionReplies: 1Last Post: 29th Dec 2008, 16:39 -
"Unknown Disc" error for all DVDs - is my player dead?
By RosieP in forum DVD & Blu-ray PlayersReplies: 6Last Post: 8th Nov 2007, 07:49
