I am trying to use the VCD header trick in TMPGEnc to multiplex an SVCD MPEG2 file to MPEG1 (file >> MPEG Tools >> Multiplex). After the process reaches 7%, the indicator bar shoots to 100% and the coversion is said to be completed. However, the newly outputted file is only a few minutes long (because the process did not complete in actuality).
The original SVCD file plays fine...and so does the new file, although it is truncated. How can I ensure that the multiplexing process goes through to completion?? This has never happened to me before.
I've had something like this happen before. What I am about to suggest may not work for you but it did for me.
Try demultiplexing your file and then re-multiplex the m2v and mp2 files. Then try the header trick on the newly created file. I know it sounds like a pain but it might be worth a shot. -
I tried your suggestion, but I'm running into the same problem. The process works until 7% and then finishes abruptly.
Any other suggestions? There must be something I can do to save the file, since it works perfectly.
MPEG-2 TS PAT header decoding problem
By jeromedroz in forum ProgrammingReplies: 21Last Post: 27th Jan 2016, 05:02 -
The Film Machine Problem... MULTIPLEXING FREEZE
By supermannnnn in forum Video ConversionReplies: 3Last Post: 16th Dec 2012, 12:51 -
.264 + AC3 Multiplexing problem
By 557953 in forum EditingReplies: 4Last Post: 24th May 2011, 10:16 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 17:21
