Hi,
I'm learning TDA. So far, so good. I have a main menu with four motion thumbnails on it. I've put my own background jpg on the menu. I can't figure out how to add background music to the menu. Any ideas how it can be done? Thanks in advance.
I don't mean to be "short" with you, but I know this was talked about just yesterday it seems. It had a bunch of replies I'm sure could help you out, do a quick search on pretty much the same title you used for this thread...Originally Posted by falberni
Thanks I found it. Basically I need to use TMPGEnc Encoder to make a mpg video of my back ground jpg and the background audio added. This is the only thing I don't like about this sw. In just about all the other authoring softwares you can add a jpg as menu background and then just drag and drop your audio.
Hell, consider yourself lucky you didn't end up with Roxio's crappy authoring software like I did.....
TMPGENc Authoring Works 4: Menu crashes after I add background music
By silentmachine in forum Authoring (DVD)Replies: 2Last Post: 11th Aug 2011, 16:32 -
add background music using ffMpeg or any commandline tool (free)
By Shohag_ifas in forum AudioReplies: 2Last Post: 21st Jan 2011, 07:25 -
How to add background music?
By coody in forum AudioReplies: 2Last Post: 25th Sep 2008, 17:04 -
legality of using copyrighted music as menu audio background
By nbi in forum Authoring (DVD)Replies: 3Last Post: 20th Nov 2007, 04:14 -
DVD Lab, Is it possible to add video to background on the menu
By frozenwind in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2007, 11:09
