I am wondering what is a good web site to buy a cable like this (but without the 3 adapters). I went to BestBuy and told them what I was looking for and they looked at me like I was speaking Japanese.Can anyone help?
dj matty b
Originally Posted by djmattyb
I do have video cable like this: one BNC to one RCA. It isn't in any use at the moment and I am using the BNC adapters to connect an old BETA VCR with a VHS VCR.
The BETA machine is only in use as a sender to the computer's video card via the VHS machine. -
I found something that I hope will do the trick. It's from impactacoustics.com At $60 for 6 feet it better make HDTV look damn good on my plasma!
dj matty b -
Well, one day I'll get a large screen monitor with a HDTV box receiver and a DVD player. Should be great viewing. -
Not all TV's have BNC connections. In fact most don't, but I didn't buy a consumer grade television. I got a commercial grade, the kind you would see in the background on news shows or something. It's the Panasonic TH-42PHD6UY in case anyone is interested.
dj matty b -
wouldn't it be a lot easier to buy three of these and connect them up to a normal RCA cable?
http://www.centralsatellite.com/store/catalog/product_16652_BNC_to_RCA_Adapter.htmlSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
You are right. I should have gotten 3 of those thingies. I went to Radio Shit and they wanted $5 each for them! Well, I needed a good component cable anyways so I just got one that exactly met my needs. I don't know if it would have been cheaper because a good cable is expensive. If I need a cable with RCA on both ends, maybe I will be able to find 3 female BNC to Male RCA connectors.
dj matty b
Same cable for BNC, SDI and Composite?
By kayut in forum Off topicReplies: 2Last Post: 31st Oct 2011, 09:37 -
How do I connect my Laptop (VGA) to my TV (S-Video or RCA or component)
By setenay kabardey in forum Newbie / General discussionsReplies: 1Last Post: 3rd Dec 2010, 14:08 -
DVR card BNC Female to regular cable (rg60) conversion
By johnnyfly123 in forum Capturing and VCRReplies: 1Last Post: 27th Mar 2010, 15:49 -
Component cable
By alintatoc in forum Off topicReplies: 3Last Post: 23rd Jan 2010, 09:20 -
FML VGA to FML 2 3 pin XLR, L R Rca Audio, Composite BNC, S-video Breakout
By silverlage in forum Capturing and VCRReplies: 1Last Post: 12th Dec 2008, 11:07
