im not sure if this is a dvd reading problem like my dvd doesnt recognize a dvd r+ , but the problem is i have an apex dvd player that i used to be able to watch vcds on but now i tried svcd2dvd for the first time to burn my movies to dvd and when i put them in my apex player it cant read the disk...
nevermind i found the answer /// https://www.videohelp.com/dvdplayers.php?DVDname=ad-1201&Submit=Search&Search=Search i thought most all dvd players like dvd r+ and not the dvd r- , i only got a dvd r+ burner
but i do have another question is the anyway to add more text to the dvd menu maker ... like i want to add dates at the bottom of the menu but the menumaker only allows you to have the movies names on it
also i had a menu problem in my other dvd player a classic dvd102 ...
when i made the menu it came up all scrambled and i couldnt select the movie to watch.. did this have anything to do with not selecting between pal and ntsc in the menumaker? i think i might have selected pal even though i think i should have selected ntsc cuz im in the US -
also maybe add a function to allow titles to have different fonts instead of the same font for each title
Originally Posted by illwillGreatings,
Yf -
"You need to select the same standard as you mpgs are. If you got NTSC mpgs you need a NTSC menu. And check if your dvd-players plays PAL that might help with discovering a solutuin for your problem."
I never got that problem, I'm mixing ntsc/pal but use pal menu becuse my TV does'nt support ntsc. Don't know if I can use ntsc menu. My player have ntsc -->pal built in. Think most have. -
Originally Posted by semi
Originally Posted by semiGreatings,
Yf
XP Pro doesnt recognize USB flash drive
By rubberman in forum ComputerReplies: 31Last Post: 6th Feb 2015, 13:57 -
Windows 7 doesnt recognize jvc gr-d796u camcorder
By ot5707 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 15th Jan 2012, 02:27 -
help Drx-710ul Doesnt Recognize Dvd+r
By aqua in forum DVD & Blu-ray RecordersReplies: 3Last Post: 23rd Jun 2008, 22:57 -
5982 doesnt recognize correct SRT file
By chits007 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 31st Mar 2008, 23:30 -
Why doesnt DVD play on mac/PS3/dvd player
By chronic777 in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2007, 13:06
