I tried to burn this movie and this is the error i got:
"Since disc media come in different information capacities, ensure that your target media is larger than the source media (e.g., your target media is an 80-minute capacity disc and your source media is a 74-minute capacity disc)".
although the files add up to be around 3.7 gb, it should fit on the 4.7 gb dvd+r cd. so can you tell me what the problem is or how i would correct this? thanks!
Results 1 to 9 of 9
tvandang
i always use dvd shrink but 3/4 through it, it failed and i forgot what the error was. can you always rip any movies using dvd shrink without problems even with new movies that have recently come out?
i followed the guidelines on this forum by using dvd decrypter and then use dvd shrink since using dvd shrink did not work for this particular movie. once i completed those two steps, i then use record max burn application to burn this movie onto a dvd+r cd. when i tried that it prompted me with this message.tvandang -
i always use dvd shrink but this particular movie failed. so read on this forum and it said to use dvd decrypter first to put the movie on your hd and then use dvd shrink to shrink the movie and that does not cause any problem this time doing these 2 steps. when i tried to burn this movie to a dvd, it gives me the message that i first stated.
tvandang -
hmm, try burning with dvd decrytper.
also make sure you're using dvd disks instead of cd disks. -
how can i burn it using dvd decrypter? i already have all my dvd movie files in the video_ts folder.
tvandang -
use imgtools to convert your movie files into an iso file.
open up dvd decrypter, and change the mode to iso-write.
select the iso file you created with imgtools and burn.
Can you fit multiple movies on bluray media?
By rz514 in forum Authoring (Blu-ray)Replies: 12Last Post: 28th Apr 2013, 00:29 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 09:59 -
Please explain this to me (lengths of video that an fit on a DVD media)
By perfection in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2008, 19:32 -
Didn't really fit anywhere else... (force media players to loop)
By antipepsiinc in forum Off topicReplies: 1Last Post: 26th Mar 2008, 12:37 -
How many can I fit on a DVD?
By love2learn in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2007, 12:46
