  1. I used to have VCDToolsX or whatever it was called, but i reformatted and now I don't know where to get it... can somebody help? thanks!!
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Dude. 20 posts down is the answer. Please try to search before posting.
    Answer Shortcut
    Dec 2003
    It would be nice if VCDTools would show up when you go to the Tools part of this site, do a search for Mac Tools, but it doesn't, anyone know why. I think that's why this question is asked so much with regards to VCDTools. Users just figure that if it's not part of the general tools catagorie for mac then they have to go thru some crazy way to actually get the software.
    If the Thunder don't get you,
    the Lighting will.
  4. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    wow!
    in that case they are missing LOTS of apps.
    my general rule... if it aint on versiontracker.com or macupdate.com it doesnt exist or its not worth getting
