Hello, I may have seen this a while back or I could be wrong but, is there a guide anywhere that tells you the proper way to install/uninstall codecs?
Thank You
This might be what you want ...
http://www.jsiinc.com/SUBH/tip3800/rh3868.htm -
an even easier way (free also)- great program (for both audio and video)
http://www.analogx.com/contents/download/audio/dxman.htm"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
StaxRip XviD Install Guide
By Trac in forum User guidesReplies: 2Last Post: 8th Jun 2013, 01:08 -
Screwed over by a CODEC install
By AveEye in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2012, 04:34 -
Quicktime wont uninstall/install
By loa909 in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2009, 13:44 -
uninstall every trace of any video codec
By greendesert in forum Software PlayingReplies: 8Last Post: 20th May 2008, 10:27 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43
