Im having trouble finalizing my dvd-r with nero 6 im using dvd decrypter to copy the dvd to the hdd and dvd shrink to compress it but when i burn the files with nero at the end when it is finalizing the disc i get an error it also happen to me when burning with instant copy , the extrange thing is that when i try burning the same files to a dvd rw i get no error messages and the dvd can be played in most players
thanks
one thing to look at:
if you're burning to near-full disk capacity and using an inexpensive brand of dvd-r, you might try a disk or two of a good quality media.
some of the "cheap" brands have been known to have that problem. Consult the DVD Media section over on the l/h side of this page for more info.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Nero 8 DVD menus simulate fine but transcode errors on final dvd movie
By perfection in forum Authoring (DVD)Replies: 1Last Post: 1st Nov 2008, 04:01 -
DVD copying with Nero - demands DVD/RW disc and still doesn't work.
By gorelle in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2008, 05:44 -
why could I only put two movies on a DVD disk when I use Nero to burn DVD?
By efang622 in forum Authoring (DVD)Replies: 7Last Post: 24th Oct 2007, 09:40 -
Have your NERO & sub it too... add subs to episodic DVD's with DVD-lab
By KneeRow in forum User guidesReplies: 1Last Post: 24th Aug 2007, 02:16
