Results 1 to 13 of 13
  1. Ive backed up my R1 copy of The Beach using cloneDVD and have the Video_TS folder on my HD, however before i burn i would like to region free it, can anyone point me in the direction of a guide or give some pointers?
    Many thanks in advance!
  2. Go to this site and download IFORegionFree01.zip. Its a good tool.
    http://www.mrbass.org/dvdrip/
  3. thanks for that will try it tonight!
  4. or you could use ifoedit and just open your ifo files and hit region free then save the new file (this works fine for me when doing rce discs)
    I could dance with you till the cows came home..... on second thoughts i'd rather dance with the cows till you came home.
    Rufus T. Firefly (Groucho Marx)
  5. well im still having problems, ive regioned free the movie using ifo edit, and since tryed with dycrypter as well, i was wondering if anyone can point me in the direction of a guide or something that would let me strip out those screens?, ive burnt to a disc and its reading it as having no rce protection yet it still wont pay!
    any help appreciated!
  6. Open ifo edit, open the first ifo file in your video_ts folder and click region free, if it's rce it will ask you which region you would like rce checking to be so click the region of your dvd player. If it's not rce it will just say "no rce checking found in this ifo, enjoy your region free dvd!" then click the save button and it will ask you if you want to save it as a bup aswell click yes. Then do the same with each ifo file in the folder as they sometimes put rce in other ifo files, also when your ripping the disc in the first place make sure the region free & rce removing are NOT checked (as this messes things up)
    I had problems at first but when i did it this way it's been fine ever since.
  7. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Maybe I'm wrong, but if you have AnyDVD on your computer, doesn't that take out the region lock automatically when you rip to hard drive?
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
  8. No
  9. If you use dvd shrink that makes it region free, I am not sure about RCE though
    If it's wet, drink it
    My DVD Collection
    Dec 2003
    Florida, USA
    DVD Decrypter takes out RCE. Check your settings if you have tried this once. Especially if you are a region 2 or other. (That could make the difference if you are defaulted at R2 and the disc is a R2)
    Adam
    DVD Decrypter>DVDShrink>CopyToDVD
  11. thyanks for the help guys, turnt out my settings in dycrypter were notr , right, as i have recently just up'ed to .19, and didnt set them!
  12. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Manual:
    AnyDVD is a filter driver and is running invisibly on your computer. You only need to insert a CSS and/or Region Code protected DVD into your DVD-Rom drive. Everything else is done by AnyDVD independently. AnyDVD removes automatically CSS and RPC transparently from your computer, while watching or copying. You do NOT need to save the content of your DVD on the harddisk.
    This is from the AnyDVD manual. How can you say it does not remove the region lock?
    Manhattan, NY
    In my experience with anydvd it must change the original files when they are used.
    I have backed up single layer dvd movies simply using anydvd and nero to do a copy...not a compression....a straight copy. And what happens? The copy I made does not have any Region coding or user preventions
