I want to create something like DivxFix, but that actually works. The only way to look for invalid/error in freames that really worked is by using besweet, it tell's u at what time the error happened, so i had to go with to that time in the movie and check what frames are wrong.
I used virtualdub mp3 but it didn't detect errors.
So I want to be able to:
+ Read a movie file
+ Check each frame for errors
+ Cut the frame(s) and reindex.
I was trying to get the code for virtualdub, but I don't think it includes the code for error checking, because it's from the MP3 MOD. Any link/suggestion is appreciated.
First of all, you can obtain the code for VirtualDUB mod as well. In case what you want can be found there.
As a general comment, the main problem in fixing corrupt frames is ensuring audio sync. If you need to only drop a frame, then the audio will be so little out of sync that will not be noticed. If however, you need to drop a few frames here and there, audio - unless something is done to it as well - will start to lose sync. A second's worth of shifting for every 25 frames for PAL and 29.97 for NTSC.The more I learn, the more I come to realize how little it is I know. -
I only saw the code for the original virtualdub listed in their web site. I don't know where I can find the source for the other MODs.
If you cut a frame, you would do the same for the audio, otherwise the put of sync problem will show up. I'll try to to the same when you remove frames from virtualdub.
Remove frames from an iPhone 4S video (MOV) without re-encoding?
By kingmustard123 in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2011, 11:18 -
Remove Duplicate Frames
By robindean in forum Video ConversionReplies: 26Last Post: 11th Mar 2010, 15:30 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 12:27 -
How to remove a single or more frames from a DVD
By justmehere in forum Authoring (DVD)Replies: 2Last Post: 22nd Apr 2008, 12:06 -
Remove green color from 49 frames
By mlong30 in forum EditingReplies: 5Last Post: 10th May 2007, 23:54
