hai i'm a newbie
i have a lot of (self-made) mpeg-movies (holiday).
I want to edit these movies (ie: merge, cut, rotate etc).
Which program would you recommend?
I am on the apple-platform.
Should i transform the movies into another format?
thanks for your help
roger
netherlands
Results 1 to 9 of 9
rogier schade
I have never owned a MAC but has checked it out in a local pc store and I must say it is awesome. I have see various posts about using I-Movie alot.
Yes
imovie i supposed to be very good. Unfortunately, it is (to my knowledge) not possible to import mpeg movies in that program.
therefore i am in need for another solution...rogier schade -
Hi rpschade,
I've seen mention of a program called Womble that can successfully edit mpeg's - though I don't know if it can be used on an Apple. I don't know where you can get it from though - just seen it mentioned. There is another reliable one, but can't rememeber the name.
I've also seen regular mention that editing mpeg's (excluding the above 2 apps) is tricky and often leads to a/v synch problems. Common consensus seems to be edit in AVI and then encode finished article to mpeg.
Hope that helps... Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I have moved this to the Mac video forum as you are likely to get more help here.
MPEGs are hard to work with because of the audio codec and the way they are multiplexed. Somebody will tell you the programs to use in a couple of hours (and hopefully they will have gotten some sleep)
I'm not aware of any programs that will allow you to edit the mpeg file directly. One way would be to demux the mpeg into streams. Convert the video to .mov and the audio to .aiff. Then import both of them into FInal Cut Pro. It allows you to edit, cut, crop, rotate, etc. You can then export back to .mov and author as an mpeg again.
alright i understand that i will not get any further with movies in the mpeg format. Are there any suggestions about which program i should use to convert the files. What format is avi exactly?
Final cut pro is a very expensive program, are there less expensive options?rogier schade -
MissingMPEGTools comes to mindOriginally Posted by rpschade
Not to sound smart, but it's AVI formatWhat format is avi exactly?
My brother has a program that roates video and it was only $10 i believe. I'll post it when I get homeFinal cut pro is a very expensive program, are there less expensive options?
Newbie bluetooth questions
By videohalp in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2011, 05:37 -
couple newbie questions - DVD to MKV and watch on WDTV
By timmyinnis in forum Newbie / General discussionsReplies: 7Last Post: 26th Apr 2010, 04:14 -
Newbie questions about HD camcorder etc!
By n33712 in forum Newbie / General discussionsReplies: 10Last Post: 4th Mar 2009, 15:16 -
Newbie Questions DVD to ????
By swezey in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2008, 10:19 -
Some newbie questions about sirius
By janeydoll in forum AudioReplies: 9Last Post: 10th Jun 2008, 02:19
