I have a SVCD-movie thats in 2 mpg-files (800 Mb each). Is there a way to make them fit on a DVD or convert them so they become a real DVD?
A first method involves re-encoding each file with DVD preset (also enable "Decode with mplayer" and disable "Author as DVD") and then use Sizzle to build a DVD from the two resulting mpg files.
A second, faster, method is to put your two mpg files in a folder, and run the S/VCD>DVD tool on that folder. The mpg file is in such case authored as a DVD without re-encoding the video. However, the resulting DVD will not be totally compliant and only some players can play such "SVCD-DVD" (see player compatibility list in this site).
LardhGuest
HI..
I have the exact same problem.
I on the other hand have got a couple of avi´s that I realy would like to burn on a DVD. I managed to convert them to 1 kick-ass-big mpg. (4,5G) But then what. I need the wobs and that stuff..
I used TMPGEnc to the mpg..
If that will get you any further and you than know the rest.. please share..
TMPGEnc DVD AuthorGuestGet "TMPGEnc DVD Author" it will do what you want simple and fast!Originally Posted by Lardh
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 10:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 03:32
