Hi all.
I try to to encode a .dv-file to divX, but mplayer crashes when he tries to autoscan the input .dv movie
After mplayer has been closed, the information line above the "Open.. field" doesn´t show any information, sometimes only the audio information.
Encoding to divX (libavec) with mencoder fails, encoding with ffmpeg works.
I reinstalled the binaries, but no change.
Any ideas ?
jaypee
Results 1 to 10 of 10
Terminal says:
Last login: Wed Jan 7 20:36:51 on ttyp1
Welcome to Darwin!
[powerbook:~] jaypeepb% ls -l /usr/bin/mplayer
-rwxr-xr-x 1 root wheel 4658648 7 Jan 18:55 /usr/bin/mplayer
[powerbook:~] jaypeepb% ls -l /usr/bin/mencoder
-rwxr-xr-x 1 jaypeepb admin 4549296 7 Jan 18:55 /usr/bin/mencoder
jaypee
Changing the extension doesn´t change anything.
Mplayer crashes, only audio info is displayed.
When I then try to encode with terminal window open it says:
Last login: Wed Jan 7 21:01:03 on ttyp1
Welcome to Darwin!
pbpaste | sh
[powerbook:~] jaypeepb% pbpaste | sh
Encoding started on Wed Jan 7 21:01:04 CET 2004
Using GNU internationalization
Original domain: messages
Original dirname: /sw/share/locale
Current domain: mplayer
Current dirname: /usr/local/share/locale
MEncoder dev-CVS-030226-15:00-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
AltiVec found
Reading /Users/jaypeepb/.mplayer/codecs.conf: can't open '/Users/jaypeepb/.mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
Using built-in default codecs.conf
File not found: 'frameno.avi'
Reading config file /Users/jaypeepb/.mplayer/mencoder: No such file or directory
success: format: 0 data: 0x0 - 0x462CD80
MPEG-PS file format detected.
Encrypted VOB file (not compiled with libcss support)! Read DOCS/cd-dvd.html.
MPEG: No audio stream found -> no sound.
MPEG: FATAL: EOF while searching for sequence header.
Video: Cannot read properties.
Exiting...
Successful.
mplayer autoscanned the file correctly now.
But where´s the problem ?
The original .dv was exported from imovie as "Quicktime movie/dv high quality"
I think I'm getting the same issue.
Scenario: 5GB .mov digital video file. Mplayer crashes during scan of file.
From the crash report Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000030
From Terminal (using commands below):
Last login: Wed Feb 4 21:25:02 on console
Welcome to Darwin!
Erins-Computer:~ Jon$ ls -l /usr/bin/mplayer
-rwxr-xr-x 1 root wheel 4658648 4 Feb 17:19 /usr/bin/mplayer
Erins-Computer:~ Jon$ ls -l /usr/bin/mencoder
-rwxr-xr-x 1 root wheel 4549296 4 Feb 17:19 /usr/bin/mencoder
The file has an .mov extension. I'll try Quicktime Player.
KAR
I had the same problems like you with .dv material from iMovie 3;
I could get mplayer to scan it by exporting it differently:
Choose export, then QT Film; use the setting dv-stream, and go to options; choose video medium quality and audio 32.000 Hz and locked/protected
It then works fine fo me, and i can use ffmpeg to export to DivX .avi
Arnaut,
Thanks for the help. I used FCE2 to export as DV. And, we got about 1/2 way through before the entire computer crashed. I'm trying again using mplayer to decode instead of Quicktime. Has anyone had issues with QT6.5?
KAR
MPlayer stream error
By nic3 in forum Software PlayingReplies: 0Last Post: 31st Jul 2011, 18:23 -
Mplayer as an *encoder*?
By RogerTango in forum Video ConversionReplies: 5Last Post: 31st Jan 2010, 11:59 -
MPLAYER pipe to MENCODER possible?
By neapandele in forum Newbie / General discussionsReplies: 0Last Post: 27th Oct 2009, 06:56 -
mplayer freeze
By ajv in forum ffmpegX general discussionReplies: 2Last Post: 7th Jul 2009, 17:15 -
Newbie Mplayer questions
By Maikeru-sama in forum Video ConversionReplies: 2Last Post: 21st Dec 2007, 14:51
