hi guys
new to this so please be gentle with me
when i use svcd2vd its making the film way to big for a dvdr disc
its coming out at 5000 mb
this is what i do
download film (2 parts)
extract with winrar
mpeg with vcd gear (each part)
merge with tmpgenc
then run in svcd2 dvd
end result way to big!!!!
anyone help thanks
Hey,
first 2 tips:
1. Never talk about downloading films here cause it is illegal to do and you can't talk about illegal things on this form.
2. If you got .mpg it is better not to merge them. Cause merging will problably give you video/audiio sync problems. SVCD2DVD will append them when authoring without problem.
I also got a question: How big are your files, the 2 parts not the merged file cause we don't use that one. Cause it should be able to fit on 1 dvd. You only have 2 SVCD which should be about 800 MB each so that would result in a 2 GB final project.Greatings,
Yf -
Ok Ditto to what yf2001usa says about downloading file...That the legal stuff out of the way....Originally Posted by samstone1968
What you need to do is.
Unrar, at a guess you will end up with bin and cue files.
Put them into a folder, select that folder in svcd2dvd, select a folder to output the finished files to (can be the same if you want dont make any speed diffrence). Select any chapter point times if you want and hit start.
Should end up with a file No bigger than 2 gig proberly 1.5 to 1.8 gig...Not bothered by small problems...
Spend a night alone with a mosquito
YAAI help needed
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 24th Apr 2011, 06:18 -
AviSynth much needed help!
By dbanimal in forum EditingReplies: 18Last Post: 28th Jan 2011, 11:33 -
HELP!! New Camera Needed
By hhouser in forum Newbie / General discussionsReplies: 1Last Post: 8th Nov 2010, 06:05 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
