HI to you all!
I`m looking for a good and full guide for converting AVI.MPEG into RM files. I`m interested in rm movies that can be played on N-GAGE. 178*144 res . I allso need a recomendation about a program that will do it the best way and that supports all AVI files as DIVX,XVID.
you don't want to watch rm movies on a ngage. you think you do, but you really don't. you want full res, full quality files, trust me.
I`ve allready decoded movie for N GAGE and it is amazing good res compere to a cellular and yep i do want to decode more... but the problem is that most of the programs are very limited and does not support all codecs.
I own the N-Gage and I did a few encoding from .avi to .rm. I would recommend you to look out some online tutorials from some n-gage groups that deals with N-Gage .rm encoding to the correct resolution and framerate. I guess, watching a movie on the N-Gage is not a bad idea, at least that's one of the best thing you can do when you are on a train ride
what you see is not what you get -
can you give me any address for a group like the one that you said here?
isnt there anyone how can make a guid on how to encode avi to rm??? -
hi just read that u converted a movie for your n-gage what did u use to convert the movie with and how good was the quality ???????
the program that you said is very limited in options and does not compress the file too good. i work with it but it`s not satisfaing!!!
i tryed to work with cleaner xl but some movies was encoded in mirror view!
Conversion help.
By yugub in forum Video ConversionReplies: 9Last Post: 18th May 2011, 20:45 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 18:36 -
2.35:1 conversion to 1.85:1 (or 1.77:1)
By mgarrido in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2007, 23:21 -
Conversion
By firoril in forum Video ConversionReplies: 1Last Post: 2nd Aug 2007, 10:46
