What program can I use to join WMV quick and easy without having to encode.
I dont know of any truly easy ways, AFAIK TMPGEnc cant join wmv, so try Asfcut. Its DOS based so a bit of typing is required.
if you want to join 4 files, the easiest way I have found is create a text file in the program directory, say "list.txt", which contains all the files you want to join, ie.
a.wmv
b.wmv
c.wmv
d.wmv
then save the file and open up your command prompt, "cmd" from run menu, navigate to the program directory, ie
cd ../../Program Files/Asfcut/
or wherever its located then type the following
asfcut -l list.txt -o output.wmv
then your joined file will be created in the program directory as "output.wmv" -
Real simple program is Filemerger from the 'Tools' section to the left. Works with most any binary file. I use it for AVI's and MPG's. Should work with WMV.
Quick easy way to convert DVD subs from 25fps to 23.976fps?
By nick1977 in forum SubtitleReplies: 19Last Post: 22nd Feb 2015, 18:36 -
A quick, easy, and accurate way to test MKV files?
By guht in forum Newbie / General discussionsReplies: 2Last Post: 1st Dec 2010, 11:25 -
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 17:57 -
Easy way to join 2+ AVI files
By AppzBeWarez in forum EditingReplies: 2Last Post: 8th May 2009, 00:48 -
Quick and easy DVD9 to DVD5 video backup under Linux
By danboid in forum LinuxReplies: 7Last Post: 30th Sep 2007, 12:05
