i've got a 320X480 mpeg that i want to burn to a dvd, but i have to change the resolution first...
is there any way i can do this?
what program do i need?
You will need to re-encode, try TmpGenc.
Or you could try and fool the authoring software by patching the header info. Try DVDPatcher for this. -
absolomj,
Now others may suggest as your post stated that you change the resolution to be DVD compliant but what you have should work just fine. It does for me. In fact I have a number of xVCDs that I have put onto DVD with the same resolution as you have. In fact, I have several VCDs that were just authored and burned without any change (i.e., video nor audio). So far they work as advertised. I even have a few xVCDs at 352x240 that work just fine. However, the video is definately not DVD quality. But for me that is OK.
Thus, from my experieces and with what data you have provided, technically, I do not think you have to change the resolution. But for greatest compatibiliy (with some loss in quality) you can recode to DVD resolutions. TMPGenC is a good one for that.
On a different note, you did not mention converting the audio. And once again, my experience shows that this is not absolutely necessary, either. But for greatest compatibility, I would consider changing the audio to 48KHz, if it is not already at that freq.
Converting the audio is a fairly easy and straight forward process.
It requires demultiplexing the mpeg file into its video and audio components. TMPGenC is a good program to do this. Then there are many programs available to convert the audio from 44.1KHz to 48KHz. Goldwave, SSRC, TMPGenC just to mention a few. Once you have the new audio file, then TMPGenC can remultiplex the video and new audio files together into a new MPEG file. Then author this mpeg file and burn accordingly.
In closing, I may be lucky in that my hardware is not very picky. But, to be certain I would try just authoring your mpeg "as-is" and burning to a RW disc (cheaper this way) and view the results. If the sound does not meet your desires, then resample to 48KHz and repeat authoring and burning. If that does not meet your visual test, then recode to DVD specs and hope that you do not lose to much in the recode.
Ed. -
ok, i try to open the file in tmpeg, but it doesnt change the output file size when i reduce the bitrate...
Converting HD (1280x720) to lower resolution for YouTube
By arjanpublishing in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 31st Dec 2009, 11:17 -
Converting Avi To MP4 Ipod with custom resolution
By zander20 in forum Video ConversionReplies: 2Last Post: 28th Nov 2008, 13:59 -
Resolution problems when converting with FUW
By Malicious in forum DVD RippingReplies: 1Last Post: 8th Aug 2008, 01:02 -
Converting resolution size
By Illusionist in forum Newbie / General discussionsReplies: 17Last Post: 11th Mar 2008, 01:38 -
deciding on the correct resolution setting when converting to mpeg2
By Dreadnaught in forum Video ConversionReplies: 4Last Post: 15th Jan 2008, 08:36
