  1. I am trying to convert a movie from divx, and I have already converted it, using TMPGEnc (whatever yesterdays version was), then I cut it using it too. I thought it was perfect, so then I went to burn it using Easy CD Creator Platinum, and it said that it wouldn't play as a VCD because the System Clock Reference was wrong. It says that it is 1230. I have no idea how to change it. Should I use another program to burn it? Oh, I burnt it anyway and it wouldn't play (I know, how stupid of me). I know my DVD player supports VCD.
    Please HELP!
  2. I have the original DIVX, the Conversion to MPG, and the MPG split up.
    May 2001
    London, UK - Bonn, Germany
    When you used TMPGEnc did you use the VCD NTSC template?
  4. Ok, I think that was my prob, I'll be back to see!
  5. Im really retarted that i didn't figure that out before. I just got to 1% and aborted, went to the program, and put it on the file list. It didn't come up with any errors, thanx a lot!
    May 2001
    Don't worry too much about it. We often overlook the obvious <grin>
