  1. well i mainly use dvd-lab for my authoring but it has a very poor button library is there any package out for buttons for it or for any other purposes that i can import to it?
    thnx
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    since it will accept multiple image formats, I would look on any free-graphic site on the web and find buttons you like in .png or .jpg format.
    or use a graphic editor and make your own custom buttons.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. Member Ziffelpig's Avatar
    May 2003
    Soviet Canuckistan
    Try DeKnop, makes great buttons, and you can export to png format. It's also free
    Just shut up and listen dumbass
