Just so I dont screw things up. Is it possible to backtrack to an earlier firmware version. I upgraded my Plex 708a to 1.04 and nero 6 now makes coasters with the Memeorex +r's. I use to burn them at 8x and now Nero will not pass 99% and hangs. The plextor site states that any firmware after 1.02 can not be retro fit to earlier versions. Anybody done a retro fit of earlier version of a firmware on the 708a. Is it possible. 1.02/03 worked fine, either 1.04 or Nero 6 is now causing prob's.![]()
Nero 6.3...but it seems to work now that I completely uninstalled and un-register all AHEAD in regstry and folders and reloaded Nero 6.3 twice. But it seems to only burn my Memorex 4x discs now at 4x when it use to burn them at 8x. Nero says 8x but it takes ~15 min so it seems to be burning at 4x. Well at least its no longer making coasters.
Still wondering if is possible to retro fit previuos versions of firmware on the Plex after 1.02 tho
Thanks for the help
I did it without really thinking about it, but everything is working fine. So i think it could be done.
Well I retro fitted 1.03 and it didnt make any diff in burn speed. Reloaded 1.02 and will experiment some more to see if the Plex will do 8x. So you can retro fit the earlier firmware on the plex 708a. Now let see if its a Nero 6.3 prob.
Retro consoles on my Retro TV have a weird angle on the right side.
By the_importer in forum Off topicReplies: 2Last Post: 1st May 2011, 18:35 -
Can anyone help me with SUPER ? Strange problem since an earlier version
By Alterego in forum Video ConversionReplies: 1Last Post: 18th May 2010, 06:32 -
Does Plex support .srt subtitle files?
By dutchgirl in forum SubtitleReplies: 0Last Post: 3rd Apr 2010, 12:54 -
Anyone sussed out how install an earlier version of Super yet?
By TimA-C in forum Video ConversionReplies: 0Last Post: 8th Feb 2009, 18:33 -
Need earlier versions of MSU Denoiser plugin for virtualdub
By cybertheque in forum Video ConversionReplies: 2Last Post: 15th Oct 2008, 16:32
