my firewall alerts the following:
" 'SVCD2DVD' from your computer wants to connect to www.**********.com [66.232.131.11], port 80 "
I think it's not a good style
to implement such "Ad- or Spy-ware" into a (payed) Software like SVCD2DVD !!
and why comes this alert evey 5 minutes ?
Chris ?
I never seen such a message in my firewall. If i didn't know better some cracked the program and put it in, but you got a bought version so that can't be it.
Dit you run adware if another program is doing it? Or a virus scanner to see if you got a virus?Greatings,
Yf -
You should use a better firewall
(Tiny Personal firewall - the old version 2.0.15 A is still the best)
Try www.*********.com (see my post above)
and then
try http://SVCD2DVDmpg.com
and then
tell me the difference 8) -
Mmm. I see what you mean they are the same ip...
stick a www into the http://svd2dvdmpg.com and you get the correct site.
ie http://www.svcd2dvdmpg.comNot bothered by small problems...
Spend a night alone with a mosquito -
It is neither Adware or spyware. It just polls svcd2dvdmpg.com to ensure the registration is valid. No data is sent up the wire. Block it if you wish - you will not suffer any loss of functionality.
Only convert the first 10 minutes or so ...
By GMUET in forum ffmpegX general discussionReplies: 4Last Post: 8th Jun 2011, 14:13 -
SVCD2DVD on computer without internet connection
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 14th May 2009, 17:03 -
Need to save contacts from rokr e1
By SIRCOOKS in forum Off topicReplies: 0Last Post: 8th Jun 2008, 07:30 -
Kaspersky Internet Security 7.0 installation Conflicting with Internet Exp
By Krelmaneck in forum ComputerReplies: 2Last Post: 5th Oct 2007, 03:36
