Good Morning Yall!
First, I'd like to say that this site has got to be the best DVD/Video Editing Site out there! Here is my question. I would like to buy a new computer to Capture, Edit and Burn DVD's. (Mostly convert VHS to DVD.) Here is what I would like to buy first...
MEMORY
(2x) DDR400 PC3200 512Mb AZEN RAM
HARD DRIVE
(2x) 120GB Western Digital 8 Mb cache, 7200 rpm
PROCESSOR
Intel Pentium 4 2.8C GHZ 512k 800FSB S478 (HT)
MOTHERBOARD
ASUS P4P800 Deluxe
BURNER
Already have LG 2x Write Internal
BOX
Doesn't Matter
CAPTURE DEVICES
(Currently Have) ADS USB 2.0 Instant DVD
(Will have guaranteed!) Canopus ADVC-100
My biggest question would be what kind of video card would I need in order to transfer my VHS to DVD. I only have a piuny 32 MB Geforce1 and was wondering what kind of video card I need for it not to be the bottleneck or at least be very good graphic wise..
Please post your ideas...sugestions! All is appreciated!
Feeling gratitude and not expressing it is like wrapping a gift and not giving it.
Hi,
As for memory, 1 GB seems a waste, since under no condition I have experienced more than about 300 MB are used, so, 500 MB should do.
As for Video Graphic Card, once you have a capture card, it seems to me that whatever Graphic Card you may have will make no difference.
The Graphic Card I have, Leadtek A310 TD Vivo is an excellent Graphic Card which enables also MPEG2 Realtime Capture. Yet, having a capture card that works fine for you, I wouldn't spend a cent on upgrading Graphics Card. Buy some Media instead ...
However much ram you get get a decent brand never heard of azen, good brands are
Kingston
Twinmos
OCZ
Corsair
Crucial
If your not overclocking i recommend cricual, great price/performance mix. Get 2xPC3200 sticks of whatever size you choose. -
Rkermit,
I used to use AZEN RAM memory (3x256MB PC133). Never a problem.
For video work, a 32MB video card is plenty as it's not very demanding (video is 2D). I used a GeForce2 32MB myself. A new card might help if you plan to do a lot of 3D rendering (but I'm not sure) or if you want to run a higher resolution (I like to run at 1600x1200@85Hz for video work to see more palettes and menus.)
For capture, since you will be using a ADVC100, do not forget a firewire card and you will not need anything else (unless it's already on your mobo) -
I have the ASUS P4P800 Deluxe motherboard and never had a problem. I use DDRAM 1GB TWINX1024-3200C2 COR RT from newegg. Its a twin pack from Corsair. I also upgraded my power suppy to POWER SUPPLY ANTEC TRUE430 ATX RTL and added an extra fan. You may want to get a new case rated for the P4 if your case doesn't have adequate cooling.
BertPIV-2.4G ASUS MB, 1G Mem, WinXP
Novice needs advice on buying an HD Camcoder.
By gott in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 4th Sep 2010, 16:07 -
Buying a new PC - Looking for free advice!
By pdailey16 in forum ComputerReplies: 5Last Post: 5th Aug 2009, 01:25 -
Need advice about buying a Dvd-R DL burner
By southrngntlmn1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 23rd Apr 2008, 13:12 -
Need advice on buying 1st LCD TV
By majax79 in forum Off topicReplies: 12Last Post: 5th Nov 2007, 12:22 -
Need advice for buying a new monitor
By doomdoomdoom in forum ComputerReplies: 26Last Post: 6th Aug 2007, 04:53
