I alway use the default ntsc encoding which turned out fine in my TV
but i just find out that my TV picture type is Pal
so should i change to Pal encoding of movies or stick with Ntsc
anyway... what's the difference between Pal and Ntsc?
thks 8)
Fact is stranger than Fiction
1) you could try one in PAL and see how it works with your particular setup.
2) see glossary in l/h colmn this page -
Where exactly in this world are you located?Originally Posted by rock
If you are in the UK, Europe or anywhere else that isn't North America, PAL is where you want to be. You are fortunate in that all PAL DVD players can play the inferior NTSC standard. Think yourself lucky you're not in the US and doing it the other way round. Hardly any NTSC DVD player can handle a PAL disk.
PAL = 720 x 576, 25fps
NTSC = 720 x 480, 29.97fps
Encoding trailing effect PAL > NTSC
By KarenM in forum Authoring (DVD)Replies: 0Last Post: 10th Jul 2010, 14:04 -
AVStoDVD - PAL encoding, video corrupt. NTSC works
By Paker in forum Authoring (DVD)Replies: 1Last Post: 1st Mar 2010, 16:47 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 18:59 -
avoid Ahead/Nero's InCD like the plague
By JohnnyBob in forum Newbie / General discussionsReplies: 14Last Post: 14th Feb 2008, 16:58 -
Encoding DVD to play NTSC given original footage shot on PAL
By ivo in forum Authoring (DVD)Replies: 7Last Post: 15th May 2007, 10:10
