I have an avi file (DivX) which I am trying to convert to MPEG 1 for VCD output. Whenever I input the avi into CCE and click encode now (after chooseing Video CD) CCE just hangs. It displays the total number of frames but then does nothing else.
Anyone have ideas how to fix this?
I have been unable to use CCE with DivX 5.0. It would either state that there is no proper decompressor for DX50 files, or would say that the number of frames received was incorrect or do nothing or encode, but produce a black file
The only codec for AVI that I have succesfully used with CCE is hufyuv. If I want to encode with CCE, I take it through VirtualDUB and convert to hufyuv first and then to CCE. It takes time and HD space though.
Another option would be to frameserve to CCE, tried that but it's messy and only sometimes works.
I agree that Tmpgenc is a much better solution. Free and fast of VCD.The more I learn, the more I come to realize how little it is I know. -
DX50 is an effing pain. Change the 4cc header and encode away (works for me every single time).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Change the code? how? is there any utility or do it with a hex editor? And change it into what? Any suggestions?Originally Posted by GazorganThe more I learn, the more I come to realize how little it is I know.
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 12:46 -
how can i input avi (xvid) in megui??
By crb in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2008, 13:01 -
CassetteDV - Input from raw dv avi files?
By ICTag in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Nov 2007, 05:06 -
Input video size problem with AVI ReComp
By 4194 in forum DVD RippingReplies: 0Last Post: 26th Aug 2007, 14:43 -
[Help] PC hangs after playing AVI files !!
By lovelywaz in forum ComputerReplies: 15Last Post: 24th May 2007, 12:28
